Radiosity and radiosity override materials
Luigi ascione
Hi guys
i am working on a animation project.
I have modelled it and it looks good in lightscape.
Now, becouse i want animate the model with
rpc moving people and cars, i am forced to
render the model in viz. Which is fine.
The problem is that i cannot get the same effect in viz4. Trying many setting: I have set the sunlight and skylight, enviroment, exposure,
radiosity to 85% and the rendering looks crep.
What should i do to get a similar effect to lp
or if not the same, acceptable.What are the
necessary steps to follow.
I also imported the ls file in viz4 but it looks
bed (its not the same thing.Hmmmm. :(:(
Thanks for your help
Hi cesar, Thanks for the reply.
i have attached the files.
The lp image are just testing for the model
and they have some chrome and glass applied
to see the effect.
the viz file has got radiosity at 60% and same materials applied. (not sure how st materials for radiosity in viz - used radiosity override mat)
the differents - you can see yourself.
I am not an expert on viz! of course!
any suggestions? and what should i do to set right the materials?
I appreciate your help.
note: i have tried many things as exposure,subdivision, daylight settings etc etc.
i don't know what i am doing wrong.
http://www.cgarchitect.com/forum/filepush.asp?file=lp_test_01.jpg
Those light artifacts can be eliminated by using regathering.
DONT use regathering just yet. Regather adds a TREMENDOUS amount of time to your renders and, IMO, you can achieve great renders without it ;) . First, i'd suggest the threads below:
http://www.cgarchitect.com/ubb/ultimatebb.php?ubb=get_topic;f=29;t=000006
http://www.cgarchitect.com/ubb/ultimatebb.php?ubb=get_topic;f=34;t=000001
Before you try regather, check your units and make sure you have an appropriate mesh subdivision size. I never use regather and think it should be used as a last resort.
DONT use regathering just yet. Regather adds a TREMENDOUS amount of time to your renders and, IMO, you can achieve great renders without it .
if you are doing an animation, try to solve the problem without regathering by subdividing the mesh further. Also as stated, check your units. However if it is just still shot I would render it with regathering. I really think it is up the scene. I find regathering very helpful in interior scenes.
Thanks very much guys.
with your help i am starting to understand
much more of viz4.I will try all your advice today
and let you know.
Also i would like to sent you the materials
settings but i think is the same if i tell you
that i have used standard materials from viz
and used radiosity override on it.
What and how should i make a material in viz
that is good for radiosity processing.
eg. how would you create a chrome material?
Also the texture sky - if i apply a color or texture to skylight settings, would i get an
effect in the glass as happen in lightscape?
When i use a sky color in lp and i render the image, the glass always pickes up a kind of that color that i have set in the property background
color - how do i get the same in viz?
i read somewhere that i can use a texture bitmap
in the texture sky and use the rgb value as illumination map!!! How?
Thanks
luigi
