difference between vray material and standard materials
jackoftrades
Vray materials from the moment that you use Vray are faster for Vray to calculate than standard materials. Also if you have a wall bitmap and you want to use it just attach the bitmap to the vray material and assign it to your object...
Even if you make a standard material and assign it vray will propably calculate it as well... but try to stick to vray meterials cause sometimes you may have problems...
