thickly Posted October 17, 2007 Share Posted October 17, 2007 For some reason I cannot get two vertices on the same spline to weld. I must be doing something wrong here, or have some setting adjusted incorrectly. I have tried adjusting the threshold but nothing I do seems to work. The vertices are definitely on the same plane and are directly on top of each other but no matter how many times I hit that "Weld" button nothing happens. Please tell me there is something stupid that I am overlooking -- it happens on every file I try to open. Link to comment Share on other sites More sharing options...
denham Posted October 17, 2007 Share Posted October 17, 2007 Fuse them first, then weld. Link to comment Share on other sites More sharing options...
Ausmax Posted January 6, 2010 Share Posted January 6, 2010 Hello denham, I am having a similar issue with vertices. I have tried to fuse before welding and I still not able to weld. Anymore thoughts? Ausmax Link to comment Share on other sites More sharing options...
postite Posted January 6, 2010 Share Posted January 6, 2010 Hi, You can check you don't have two segments overlayed in the same spline. Link to comment Share on other sites More sharing options...
tommyjj Posted January 7, 2010 Share Posted January 7, 2010 i have the same problem with poly editing... i just convert it to a mesh and then weld the verts. always seems to work. Link to comment Share on other sites More sharing options...
Ausmax Posted January 10, 2010 Share Posted January 10, 2010 i have the same problem with poly editing... i just convert it to a mesh and then weld the verts. always seems to work. I'll see if I have two segments overlapping - good suggestion. I have tried to convert it to editable poly, mesh but the problem is that my lines disappear all together. Link to comment Share on other sites More sharing options...
