sanmb Posted October 18, 2007 Share Posted October 18, 2007 Is it possible in rhino, I want to off the shadow cast of the specific object. For example, If I model a sphere for the sky background the shadows of the model drops on the sky. I want to give light source effect to the object. For example, ceiling lights like we do in max. Please tell if anybody knows. Regards, Sanjay. Link to comment Share on other sites More sharing options...
kippu Posted October 18, 2007 Share Posted October 18, 2007 are you using any render engine or the default rhino.. in which case i wont be of any help Link to comment Share on other sites More sharing options...
vkirchner Posted October 18, 2007 Share Posted October 18, 2007 Sanjay, I am not sure I understand exactly what you want to do because you mentioned 3DMax lights which I have not used before. But I will try to help because you say that it is urgent. Using the default Rhinorender, there is an automatic light placed in the upper left corner of the screen. You will automatically turn this off when you place your own light from the render submenu. What I tell you about the Rhinorender is also true for the Treefrog renderer, except for the fact that not all lights are supported by the free Treefrog renderer. I know that the spotlight is the most used light with the Treefrog renderer. As for creating a shadow on the background, I have done this by using a planar surface behind the object, placing my background texture image on the planar surface. This works well, but under the render submenu, properties, rhinorender option, you must also have shadows selected in the check box. If you are using Flamingo or another renderer, please let us know so we can discuss the options within those specific programs. Regards Vince Link to comment Share on other sites More sharing options...
vkirchner Posted October 18, 2007 Share Posted October 18, 2007 Blankety blankety timeout values... Sorry about the dual posts. Link to comment Share on other sites More sharing options...
sanmb Posted October 24, 2007 Author Share Posted October 24, 2007 Hi Kippu, Thanx, I am using rhino renderer. I would like to know which render engine is best for rhino. Regards, Sanjay. Link to comment Share on other sites More sharing options...
broozee Posted October 25, 2007 Share Posted October 25, 2007 Hi Sanmb, The Rhino renderer is very basic. I don't think it will allow to turn off shadow casting for objects. You would need to install a render plug-in like Flamingo, Air, V-Ray, Brazil etc. that offer those controls. Regards, Bill Link to comment Share on other sites More sharing options...
vkirchner Posted October 25, 2007 Share Posted October 25, 2007 Bill, I do not believe that is a correct statement. I opened up Rhino, selected the Rhinorender as my current render engine. When I open the render>properties panel, I have the following options to turn on or off shadows by the check box. Link to comment Share on other sites More sharing options...
broozee Posted October 25, 2007 Share Posted October 25, 2007 I was meaning, by the individual object. Not the entire scene. For example, with Flamingo loaded, you could select an object, open the properties dialog, and turn off shadows for just the one object. What version of Rhino are you using? By the looks of your screen shot, version 3. Regards, Bill Link to comment Share on other sites More sharing options...
