101er Posted October 18, 2007 Share Posted October 18, 2007 Hello, has anyone ever had an issue with saving out a rendering after it is complete? V-ray goes the whole way through the rendering process (3024x1260) and everything looks great. When i try to clone the frame buffer or save the image out to any format, .jpg, .bmp etc. I get an error message saying V-ray can not save the file. Link to comment Share on other sites More sharing options...
ITryMyBest Posted October 18, 2007 Share Posted October 18, 2007 I have had renderings hang a bit at the end but that was just until the RAM cleared. I would either render it with a specified file name in the Render Output section of the Render Dialog box or submit it via Backburner even if it is to the same machine. Link to comment Share on other sites More sharing options...
Crazy Homeless Guy Posted October 18, 2007 Share Posted October 18, 2007 i have had this problem. using autosave for the image is a work around, but it still doesn't allow you to clone the window. Link to comment Share on other sites More sharing options...
101er Posted October 18, 2007 Author Share Posted October 18, 2007 Do you think it is due to the large file size? I do not ever seem to have the problem for smaller renders like 800x600 etc. of the same image. Link to comment Share on other sites More sharing options...
Msamir Posted October 18, 2007 Share Posted October 18, 2007 Happened to me before its a memory issue I guess, here's the solution.CLICK Link to comment Share on other sites More sharing options...
101er Posted October 18, 2007 Author Share Posted October 18, 2007 Thanks Mazen. I did a search for the topic before I posted so I am not sure why I didn't find that thread, but thanks again. I will give it a try. Link to comment Share on other sites More sharing options...
jophus14 Posted October 18, 2007 Share Posted October 18, 2007 I have had this problem several times. If the image is already rendered out and you don't want to re-render you can just save the render in chunks by saving as a "print screen" image and then clip and piece the images together in Photoshop until you have the complete render. I actually used a program called SnagIt to do this once. It's a quick work around if you don't have time to re-render using the Open Exr format. Link to comment Share on other sites More sharing options...
dagor Posted October 18, 2007 Share Posted October 18, 2007 yea MazenSamir and jophus14 give you right solve. it happens when you have not enough memory. use Vray frame buffer and save image in *.vrimg or *.exr (RC5 and older version can save image directly in EXR format). with VFB image didn`t take memory because image will write on hard disk from bucket to bucket Link to comment Share on other sites More sharing options...
