christr Posted October 18, 2007 Share Posted October 18, 2007 Hi! I have a spline that I have received from a client, and I'm going to make a loft between certain parts on that spline. To do that I have to find some points on the spline. Is there a way to measure a distance from the start of a spline to a not yet defined point? Or is there another way to approach this? Thanks for any answers! Link to comment Share on other sites More sharing options...
jucaro Posted October 19, 2007 Share Posted October 19, 2007 you can use the spacing tool and place your 'point' markers on the desired position within the length of your spline path Link to comment Share on other sites More sharing options...
notamondayfan Posted October 19, 2007 Share Posted October 19, 2007 i have a long is solution- clone the spline (copy), make renderable, rectangular, then convert to edit poly. now goto create panel, turn on auto grid, then draw a box on one of the faces of poly converted spline. now adjust the length of your box to the desired length, and snap to the start point of you spline. delete the poly converted spline, and theres your measurement! Link to comment Share on other sites More sharing options...
christr Posted October 19, 2007 Author Share Posted October 19, 2007 Thank you both. Didn't know about the spacing tool, but tried it and it worked out perfect! Link to comment Share on other sites More sharing options...
