Ciemon Posted October 20, 2007 Share Posted October 20, 2007 I have problems with VRay on my 3ds Max 9. Some of the materials are not compatible and I wonder what causes this... anybody who knows? Link to comment Share on other sites More sharing options...
Chad Warner Posted October 20, 2007 Share Posted October 20, 2007 Depends on the material. Anything with a raytrace reflection will give you problems. In general you want to use vray materials when using vray for the best results. Link to comment Share on other sites More sharing options...
Ciemon Posted October 20, 2007 Author Share Posted October 20, 2007 Chad Warner said: Depends on the material. Anything with a raytrace reflection will give you problems. In general you want to use vray materials when using vray for the best results. I mean.. when i try to make a VRay material i can't find it... i have to press the "incompatible" button and some aren't even there... that's what i meant.. Link to comment Share on other sites More sharing options...
dagor Posted October 20, 2007 Share Posted October 20, 2007 first of all make shure that your production render is Vray render. second - hmm, don`t know. may be problem with plugin? reinstall vray Link to comment Share on other sites More sharing options...
Ciemon Posted October 20, 2007 Author Share Posted October 20, 2007 render is Vray render? :S i'm new to this. but atleast i thought it would work on first, second try but no no... I have reinstalled twice... -.- Link to comment Share on other sites More sharing options...
dagor Posted October 20, 2007 Share Posted October 20, 2007 i mean set your production render in Render dialog (F10 shortcut) to Vray render, not skyline. Link to comment Share on other sites More sharing options...
Ciemon Posted October 20, 2007 Author Share Posted October 20, 2007 dagor said: i mean set your production render in Render dialog (F10 shortcut) to Vray render, not skyline. oh ok ^^ thanks for the help! Link to comment Share on other sites More sharing options...
