Lee Eagle Posted October 21, 2007 Share Posted October 21, 2007 Hi all, I built a room in max and placed a landscape image in the Environment Map slot, but everytime I render the image seems as though its burnt..does anyone have an idea why this is happenning? Any help would be great Link to comment Share on other sites More sharing options...
clauco Posted October 21, 2007 Share Posted October 21, 2007 Try unchecking "Affect Background" into Color Mapping rollout. Good luck! Link to comment Share on other sites More sharing options...
Lee Eagle Posted October 21, 2007 Author Share Posted October 21, 2007 Hey clauco, the option is unchecked... Link to comment Share on other sites More sharing options...
dagor Posted October 22, 2007 Share Posted October 22, 2007 version of vray? did you use phiscamera? did you use gamma correcton or exposeure control? give us more information plz. Link to comment Share on other sites More sharing options...
Lee Eagle Posted October 22, 2007 Author Share Posted October 22, 2007 Hey dagor, Thanks for the reply. I am using 1.5RC3 didnt use a phiscamera. only 1 vray light and 1 directional light I tried the gamma correcton - didnt solve the problem... Can you please explain what you meant when you stated: "exposeure control"? I am a newbie to max and vray... Link to comment Share on other sites More sharing options...
dagor Posted October 23, 2007 Share Posted October 23, 2007 i mean exposeure control from max enviromen dialog. I never use it, but as i see some people from this forum use it. So i realy don`t know if it can affet background image i`ll test it some later. Back to your problem, try next. reset max. add image in enviroment and render it. Is it burnet or not? I`ll never had burnet images on enviroment. Where you use it in max enviroment or in vray enviromet? Image can be burned if you: 1. put it in vray enviroment slot and set multiplier more than 1 2. change output amount or cureve in bitmap. 3. something else, don`t know right now. so try make it in new scene without change. Link to comment Share on other sites More sharing options...
