murtazasimari Posted October 22, 2007 Share Posted October 22, 2007 i am doing one project and client required walk through from me i made so many walk through but i don't know how to make a walk through from VRAY....Plz i need urgent feed back if any body know plz suggest me... thank you Link to comment Share on other sites More sharing options...
PGD Posted October 22, 2007 Share Posted October 22, 2007 Heres a good start http://www.spot3d.com/vray/help/150R1/tutorials_imap2.htm Link to comment Share on other sites More sharing options...
murtazasimari Posted December 9, 2007 Author Share Posted December 9, 2007 thanks alot itz good but please tell me how i do .png images and then compiled into an .avi. That way, i won't lose all rendered frames if something goes wrong in the middle of the rendering.. Link to comment Share on other sites More sharing options...
alrawli Posted December 10, 2007 Share Posted December 10, 2007 What software are you using to make the model? If your using 3d Studio max then you can use the RAM player to view the sequence of images and then save out as AVI. Link to comment Share on other sites More sharing options...
murtazasimari Posted December 11, 2007 Author Share Posted December 11, 2007 What software are you using to make the model? If your using 3d Studio max then you can use the RAM player to view the sequence of images and then save out as AVI. I saved all my animation to .png file then i tried to convert as .avi format but i wont be able to do its automatically take as .ifl format plz tell me how i convert to .avi Link to comment Share on other sites More sharing options...
hughie Posted December 11, 2007 Share Posted December 11, 2007 there are dozens of programs that can do it with, Adobe Premier Pro is probably that easiest to pick up Link to comment Share on other sites More sharing options...
murtazasimari Posted December 12, 2007 Author Share Posted December 12, 2007 there are dozens of programs that can do it with, Adobe Premier Pro is probably that easiest to pick up Thanks hughie i will check....& hope for the best Link to comment Share on other sites More sharing options...
