jgrasp Posted October 24, 2007 Share Posted October 24, 2007 Hello I have a file created in ADT 2007. How can I import and view it in max9? After hours of work, drawing in different templates, using different objects and so on, I am far from finding a solution. I use the File Link Manager, but it seems like only splines are imported, not solid objects like walls or windows. Sometimes even splines is not imported. In the File Manager Linked files dialog box, no drawings appears (only when I have a drawing containing only splines). Max9 doesn`t import dwgs from ADT 2006, 2007, or Architeture 2008. Max 8 import from ADT 2006, not from 2007 or 2008. According to the max documentation importing from Autocad, Revit and ADT should be very streamlined and easy. In previous versions I could install a OE (object enabler) that allowed object data created in Autodesk Architectural Desktop to be accessed in max. I can`t find such a software for 2007, or am I missing something? thanks in advance Link to comment Share on other sites More sharing options...
REDVERTEX Posted February 11, 2010 Share Posted February 11, 2010 The same problem still stands. Architectural Desktop 2007 ==> 3DSmax2008 ... missing Object Enabler. nothing for MAX2008 on www.autodesk.com/oe Any idea ? Link to comment Share on other sites More sharing options...
