muchhal.sandeep@gmail.com Posted October 25, 2007 Share Posted October 25, 2007 I am facing a problem in glass when I render it from outside it is fine. But in the interior(from other side it is not seen) is it the natural parameter (am not sure) or it is mine mistake with material. It is normal glass material in MR A+D material and the only thing I have changed is colour and hmmmmmmmm I have clicked the check box highlights + FG since it was giving a lot of flickering. I have attached both the renderings. Regards: Sandeep Muchhal Link to comment Share on other sites More sharing options...
Macer Posted October 25, 2007 Share Posted October 25, 2007 The glass is still showing from the inside. You can see the difference in the brightness of sunlight on the ground - the colour of the glass reduces the sunlight on the inside. The main reason that it is so hard to detect the glass from the inside is that there is nothing for it to reflect. Some interior lighting and some more reflection on the glass material will help. Link to comment Share on other sites More sharing options...
