vray exterior lighting
kish
Try a vray dome light. Then in the texture slot of the dome light. Load an hdr map. Instance this to your material editor, then load and hdr image.
you can then use a spot light to give you some direct shadow to match your
lighting. This takes some experimenting but you can create some nice lighting. This is another approach to exterior lighting.
Good Luck:)
