Dual monitor, dual pc configuration
Hello:
I have 2 pc´s, a workstation (WS) an a rendernode (RN), and 2 monitors, the primary 22" (P) and the secondary 19" (S), so:
My intention is to work in the "WS" with the two monitors and when needed swith the "S" monitor to de "RN". to achieve this i have just conected the "S" monitor to bouth machines and can switch them with the INPUT buttom in the "S" monitor.
But the problem that i´ve found is that when setting the dual monitor in the card software (Nvidia 8800 GTS) to span mode, so i can split the image in the 2 monitors, i can only set the resolution to 1280x1024 with is the 19" resolution, but can´t adjust them diferently as i would like (1680x1050 for the 22")
Is there another way to set up this? do i have to use another software to use dual monitors? is it possible to use to diferent size/resolution monitors in dual mode?
Thank you
I'm not sure why you aren't able to change the resolution independently.
I connect 2 Workstations to dual monitors via a Belkin KVM. I also have a Macbook Pro that I connect to one of the monitors. Under 'Display Properties' all I do is select the 2nd Monitor in the window and check the 'Extend my Windows..' box and viola, I can set each monitor to different resolutions.
I also suggest investing in a KVM that supports dual monitors and USB input devices. Good luck
Than you kainoa:
That solve the problem, i was tring to do it trough Nvidia control panel, and i couldn´t configure the two monitors independient, but it was very easy the way you said, besides you can change to order of the monitors and that´s sweet.
Now i just have to figure out how to color calibrate bouth monitors to the same level, i just can´t do it manually.
Than you.
