Screening an entire drawing...
1eo
dumb question...
how does engineers screen an entire dwg so they can layout their stuff on top?
The only way that I can think, would be to create a new plot style and to take all my lineweights and modify them to whatever % screening I want.. then create a new set of lineweights with colors that I haven't use before :D
Is that how they do it?
thanks!
leo
If the drawing is inserted as an xref, in the Layer Properties Manager you can select that xref and make all the layers in it one color (what ever is your lightest line weight color) and what ever you draw on top of it will be darker. That is how we do our MEP drawings. However if there are blocks in the drawing of the xref and any lines that are not set to by layer for their color, they will not change. So everything has to have its color set by layer.
Hope this helps.
some companies will move ALL Layers To ONE Layer
explode The dwg file until There are no more Blocks
change ALL To 'bylayer', This ensures That The background
will plot in lightweight correctly, a bit more work but its worth it
The next xref update will require repeating This procedure
but This does avoid The nested bycolor Block dilemma problem
Because, I'm the only one working on it... I'll do it right the first time and keep all my lines colored by layer.
We usually do it that way anyway.
regards,
leonardo
