Arroway textures in vraymtl
sesim
Anyone have some exp in using those woods on a vraymtl and get it to show correctly? I have tryed all sort of ways for gloss,ref,spec balance but cant get it to realy work any good.
any tip?
So for all, im a inhouse 3d artist and working at a pro level with vray so this is not a noob question.
/sesim
hi Sebastian.
the words about pto level looks like noob words )) amyway what kine of wood do you want to get with vraymtl? there are wery different type of wood in reallife, despite use one texture for it. for example wood floor or polyshed wood or parquet or greenwood looks very different but you can use one oak texture.
can you show image with wood which you want?
arroway does make great textures.
as a base for the material, assign the diffuse and bump maps, and then either use the bump or specular map in the hilight glossiness slot, and make your reflection black value 10. that should give a base to work from.
hi Sebastian.
that was just the simple answers i was not looking for! i know everything about spec,gloss and bump and so on! but the vray mtl has not the same build up as a ordinary standrad mat wwere u can give the amount by spec,gloss and so on! thats was my question. so these textures are built to work in a more normal way! but its struggl to work great in vraymtl!
they shurly do! im on a client work for marbodal.se kitchen design! so i cannot show! but the diff map struggles in vraymtl for some reason. butt i will trey and tre and see...
ty
may be it`s our language barrier truoble, may be i`m realy noob, but i don`t undersand what is your question exactly.
you ask "Anyone have some exp in using those woods on a vraymtl and get it to show correctly?"
YES!! i have exp in using wood. it shows correctly for me.
but what i think correctly you can think not correctly. so may be we can take one or two images of wood as standard you need and try to do it with vraymtl? i think vraymtl is more than enough for wood or other material.
anyway my usualy wood mat is:
diff - texture
reflect - corrected diffuse texture or simple color, average amount of reflect is 200
glossy - corrected diffuse texture or another wood texture or simple color. average amount of glossy is 0.8-0.9
bump - corrected diffuse texture or another wood texture.
IOR - corrected diffuse texture or simple color. average amount of IOR is 1.2 - 2.2
i use hight IOR with small reflect
and small IOR with hight IOR.
please be noticed that i`m realy try to help. there are not any sarcasm or sneer in my word.
Dagor, thanks for sharing your settings. I was in trouble with wood material too and it is nice to hear how the others do that.
I usually use very similar settings now.
But it depends on the type of wood of course.
Sesim, here is the link for a nice collection of v ray materials. So you can study how they are built:
http://www.vray-materials.de/
I hope it would help!!!
And I think it is not important if any question is on noob or pro lever, who cares...
diff - texture
Sorry for sounding sarcastic, but im talking about specific woods! the woods from arroway.de they comes with all maps needed! but the usage of these maps are in a way trouble to get right using vraymtl! in a standard mat u have the ability to set the amount in % how much gloss and ref/spec u want! and that is in a way what these maps needs. We are rendering 300dpi brochyre prints and they need to be xact! so thats my question! not a straight question on how wood works! just how to get the arroway wood maps to work great! hope that sort things out.?
see pic below for the wood im using.
/s
now i think i understand what you want.
you can tweak texture in % too!!!
black (rgb 0) color is 0%
white (rgb 255) color is 100%
so if you want for example 90% reflectivit floor - you can ajust refl texture in photoshop to averege 200, make it not so contrasted. you can do it with glossy to. also you can do it in max, not in ps. i use output map for it. i use colorcorrect plugin for it. you can put you map in reflect slot and make this slot not 100 but 10 or 20.
The brick texture is Arroway as well. The walls were bump mapped and the underside of the arches were displaced. I couldn't get the floor to look realistic without displacement. I'm sure I could if it was one of those wood floors that has tight joints. This floor and the one in the example have wide joints. Displacement would be the only way to get a realistic result for those two wood floors.
To get that look you need to use displacement.
and what if you take the blur amount in the bitmap map to 0,1.
I found that that litle overlooked option is what causes alot of headaches, ... well... at least mine
and what displacement do you refer to here? material based or object based
If this wood floor can be done with a bump map, I would like to see someone try. Of course the wood grain could easily be done with a bump map. I'm talking about the gaps in the floor board. http://www.cgarchitect.com/vb/attachment.php?attachmentid=23122&d=1194187250
The displacement I use is the vraydisplacement modifier.
or grow its hair back.
I think when you use the material map disp. the units have to be somewhere around 0,1 and not like the bump value of 30, but i guess its the same as the bump, it just actually displace the mesh instead of tricking the eye
No material displacement is just like modifier displacement but only has 1 setting: amount. So if you don't need the control try it. I actually asked Vlado about this at siggraph because I had always thought it didn't work well until I tried it by accident. He said its fine again just missing control.
