Devin Johnston Posted November 5, 2007 Share Posted November 5, 2007 I'm using a Vray Sky, Sun and Physical Camera, what's the best way to place an image in the background; I don't want to do it in PhotoShop. Link to comment Share on other sites More sharing options...
dagor Posted November 5, 2007 Share Posted November 5, 2007 add plane with images. increase output of image in 100-300 time. or put image in enviroment slot. increase output in 100-300 time. if you work with piscam you need increase brightnes of image, or it renders dark. Link to comment Share on other sites More sharing options...
Devin Johnston Posted November 5, 2007 Author Share Posted November 5, 2007 what? Link to comment Share on other sites More sharing options...
kippu Posted November 5, 2007 Share Posted November 5, 2007 you can put it in the environment slot and increase the output value of the bitmap ...at default value of 1.0 ..the .jpg will render dark due to the physical cam Link to comment Share on other sites More sharing options...
Stephen Thomas Posted November 5, 2007 Share Posted November 5, 2007 If you're applying an image to a background plane/cylinder/dome I find the best way is to use a vray light material. That way it is unaffected by the GI and you can easily alter the brightness in the material editor if you need to. Link to comment Share on other sites More sharing options...
Devin Johnston Posted November 5, 2007 Author Share Posted November 5, 2007 I've got Vray Sky in my environment slot already; won't it change the lighting if I remove it? Link to comment Share on other sites More sharing options...
dagor Posted November 5, 2007 Share Posted November 5, 2007 put your sky in vray enviroment GI override slot and put image in max enviroment. you`ll have image in background and GI skylight. PS. output properties is in max bitmap setting. Link to comment Share on other sites More sharing options...
Stephen Thomas Posted November 5, 2007 Share Posted November 5, 2007 I've got Vray Sky in my environment slot already; won't it change the lighting if I remove it? You don't need to remove it, if you just want to have a background image show up under your render then you can use the load background option in your viewport menu. Or if you want more control over the positioning, then apply the image to a plane/cylinder/dome which gives you the option to move it around. Just watch your uv mapping isn't stretching the image. This is definitely the best way as everything gets antialiased properly unlike using alphas in PS, where you can get left with a white fringe making your background look unrealistic. Obviously try and match your image to the time of day and sun position you have set up in your vray sun/sky or daylight system. P.S. don't forget to uncheck cast and recieve shadows on your object settings! Link to comment Share on other sites More sharing options...
ipxstudios Posted November 5, 2007 Share Posted November 5, 2007 just use photoshop - then you can move the image around to the way you like rather than re-rendering. Link to comment Share on other sites More sharing options...
BrianKitts Posted November 5, 2007 Share Posted November 5, 2007 wow.... definately many ways to skin a cat.... here's my way which I find the easiest since you don't need post process, and you don't have to guess how high to raise the output level on your bitmap. only drawback is you can't count on a reflection of the background map..... place the vraysky in the environmental override as mentioned. place your new background bitmap in the max environment slot. And then in your color mapping untick the "affect background" checkbox. like I said this is the easiest, but there is one downfall, your reflected image will be dark....for instance if you are doing a generic mirror ball which we all love to play with when starting out with the physical camera, then the reflection does render black. Most the time I use a background rig with a dome, and assign a vraymaterial to the dome object, and exclude it from the GI, rather than using the enviro channel. while we are on backgrounds with vray I highly recommend checking this out....Lately I've been using a setup that was given out over on chao's forums, a guy setup a dome with a cloudmap in conjunction with a vray sky. It filters out the blue from the domemap and allows the clouds to show through ontop of the vraysky for the color change dictated by the vraysun position.....it's pretty slick.... http://www.chaosgroup.com/forum/phpBB2/viewtopic.php?t=20507 Link to comment Share on other sites More sharing options...
ctk111 Posted September 5, 2008 Share Posted September 5, 2008 Not sure if this has been posted elsewhere, but the link has changed. Hope it saves you some search time. http://www.chaosgroup.com/forums/vbulletin/showthread.php?t=38955 Link to comment Share on other sites More sharing options...
