Conor Clancy Posted November 7, 2007 Share Posted November 7, 2007 Am I losing my mind? Is there no way to update the user paths on my render farm in Viz 2008? There's no 3dsviz.ini file which made adding map paths in previous versions quite easy. But in Viz 2008 the only way I can see to do it is use the portable license utility to activate each render farm pc seperatly and update the user paths. There has got to be an easiar way of doing it than this. Any body got any ideas? Please? Anybody? Link to comment Share on other sites More sharing options...
Matt Clementson Posted November 8, 2007 Share Posted November 8, 2007 For MAX 9 and upwards (which includes VIZ2008) the configuration files are stored in sub-directories under your user profile - eg C:\Documents and Settings\username\Local Settings\Application Data\Autodesk\ - check there for the 3dsviz.ini file. Link to comment Share on other sites More sharing options...
Chad Warner Posted November 8, 2007 Share Posted November 8, 2007 There's also another ini file names "installsettings.ini" that has a line "useUserProfile" if you set it to 0, it will install the same way as the older versions. Link to comment Share on other sites More sharing options...
Conor Clancy Posted November 9, 2007 Author Share Posted November 9, 2007 Chad and Matt, thanks for the help. I'm not at my PC now but I'll check the render farm in a few minutes Thanks C Link to comment Share on other sites More sharing options...
Conor Clancy Posted November 9, 2007 Author Share Posted November 9, 2007 Matt no joy with the INI file in the documents and seetings folder. I really don't know what to do. Any other ideas? Link to comment Share on other sites More sharing options...
Conor Clancy Posted November 19, 2007 Author Share Posted November 19, 2007 Anybody? Link to comment Share on other sites More sharing options...
Chad Warner Posted November 19, 2007 Share Posted November 19, 2007 Did you try a search for the 3dsviz.ini file? Link to comment Share on other sites More sharing options...
Conor Clancy Posted November 23, 2007 Author Share Posted November 23, 2007 yes I did, but to no avail. Link to comment Share on other sites More sharing options...
Matt Clementson Posted November 23, 2007 Share Posted November 23, 2007 Do you have this file on your local workstation? If so - try copying it into the VIZ directory on the slaves. Link to comment Share on other sites More sharing options...
