chiquito Posted November 7, 2007 Share Posted November 7, 2007 Hi, I guess there are a lot of topics for just one thread, but well, I´ll take parcial responses as well. First, Im having some issues with the plot styles (lines with, colors, LT scale, etc) they wont change and or update, just in some drawings, ussually when I open an ADT file on autocad or viceversa. Is there some trick to this? Units are set to the same (metric units) What to use STB or CTB? I know one uses layers and the other colors, but what is the main advantage of any of these two? how to correctly convert them. And last, how do you use a lsp? load it? invoque it? daes it stay there? shotcuts? Sorry if they are to many questions. Thanks in advance. Martin Link to comment Share on other sites More sharing options...
neko Posted November 7, 2007 Share Posted November 7, 2007 i'll take a stab at the part about lisp, but i don't have time for the .ctb / lineweight issue right now. the easiest way to use .lsp routines in autocad is to use APPLOAD (AP) where you can either load them manually or add them to the startup, which makes them available at all times. hope that helps...maybe later i'll get back to the other questions paul Link to comment Share on other sites More sharing options...
chiquito Posted November 7, 2007 Author Share Posted November 7, 2007 Thanks Paul. I know its a lot in those questions, Il give it a try on the LSP appload Link to comment Share on other sites More sharing options...
