Sweet Architect Posted November 8, 2007 Share Posted November 8, 2007 Salam, to all i have that issue that confuse me in V-ray, i don't know if i miss sth. but each time i render an interior view and try to put a view in the environment map slot(Rendering:environment) to be seen through window, it's seemed to be dark, even i put V-ray sun outside, and the glass settings is the standard one, i don't know what the problem is:confused: any suggestions? Best Regards, Link to comment Share on other sites More sharing options...
dagor Posted November 8, 2007 Share Posted November 8, 2007 if you use phisical camera you must increase your image brightness. you can do it via output map, or via output settings inside bitmap. Link to comment Share on other sites More sharing options...
Sweet Architect Posted November 8, 2007 Author Share Posted November 8, 2007 I use phisical camera,f number=4 but i didn't understand how i will reach to the bitmap settings,sorry i'm anew user of max, i teach myself via toturials,so plz be patient while leading me advanced thanks Link to comment Share on other sites More sharing options...
dagor Posted November 8, 2007 Share Posted November 8, 2007 ok, know problem first of all there are 3 settings wich affect exposusre in phisical camera. 1 f numer 2 shutter speed 3 ISO different combination of this settings gives you differen exposure (different brightness of render) To increas brightness of bitmap for your enviroment, go into bitmap settings and increase output amount (see attachment) Also you can use plane wit bitmap behinde the window. You can use vrlight material with bitmap on the plane or you can use vrmaterial with increased output amount of bitmap in diffuse slot. If you use bitmap on plane or cylinder - exclude this geomety from GI. Link to comment Share on other sites More sharing options...
Sweet Architect Posted November 8, 2007 Author Share Posted November 8, 2007 I did what you told me, i used a plane and change the output amount of the bitmap(by the way i felt stupid when i get what you was mean:o ) however , i follow your steps and i will attach the result, but how i can exclude the plane from GI Thanks for your help:) ,appreciate that Best Regards, Link to comment Share on other sites More sharing options...
dagor Posted November 8, 2007 Share Posted November 8, 2007 playaround with output amount. it`s depend on your camera settings. you can make it brightness or darkness by yourself to exclude plane from GI (if don`t do it plane will be light your room as vraylightmaterial) just right mous button on it, go "V-Ray properties" and turn OFF generate GI and receive GI properties. Link to comment Share on other sites More sharing options...
Sweet Architect Posted November 10, 2007 Author Share Posted November 10, 2007 Thank youuuuuuu so much dagor, i appreciate your help, you don't know how it took me time searching for the information you gave to me Best Regards, take care Link to comment Share on other sites More sharing options...
dagor Posted November 10, 2007 Share Posted November 10, 2007 you are welcome! Link to comment Share on other sites More sharing options...
