markf Posted November 9, 2007 Share Posted November 9, 2007 I'm trying to add a fire effect to a fireplace in my scene. Using Max 9 and Vray 1.5. I did this recently in another project with no trouble. I create the atmospheric gizmo and size it, assign the fire effect and render. It causes the entire scene to render black except for showing the fire effect. I opened the previous saved version (without the fire effect) and it rendered black. I re-started Max and the previously saved version rendered correctly. Added the fire effect again and then the scene renders completely red. Very odd. I have to delete the effect and re-start Max to get correct render. I have used the fire effect for flames in a fireplace before with no trouble. I can't figure out what I'm doing wrong or if this is some software conflict. Any help is much appreciated. Link to comment Share on other sites More sharing options...
monkhell Posted November 10, 2007 Share Posted November 10, 2007 Maybe you ran out of RAM, check that, cheers. Link to comment Share on other sites More sharing options...
markf Posted November 10, 2007 Author Share Posted November 10, 2007 Thanks for your reply. That's a good question but plenty of RAM Some testing with small file appears that if I render the entire view, the fire effect works as it should. If I do a render-region of the fire effect, the rendering goes black and will render black from that point on regardless of rendering the view or region. I have to re-start Max to get the view to render. I worked around this by using the Vray frame buffer with "render about mouse pointer" enabled. Installing Max 2008 soon and if this remains I may mention it and see if anyone gets the same results. Link to comment Share on other sites More sharing options...
