angus Posted November 11, 2007 Share Posted November 11, 2007 Hi , I set up a small network at home with only 2 computers I am trying render a single image (single frame, not animation) using both of the computer, is it possible ? what what is the "distribute rendering" option in Vray? I tried backburner, however, is it only for animation or rendering lots of different files? And somehow i can't make both my manager and sever to render at the same time. Please, if anyone can help, how can i render a single image with multiple machines with Vray? thanks Link to comment Share on other sites More sharing options...
manta Posted November 11, 2007 Share Posted November 11, 2007 You first need to have vray installed on both...then check the distributed render box...go into settings, or whatever it is right under it, and add the IP address of both computers, then on the other computer, we'll call it the slave, launch the vrayspawner which you'll find in the 3dsmax directory, depending on what version of max you are using will depend on where that is (they keep moving the directory around), once the vrayspawner is running (only on the slave by the way) then try rendering...you should see the buckets of the slave computer showing up in the render window... Link to comment Share on other sites More sharing options...
alex3d Posted November 12, 2007 Share Posted November 12, 2007 yes angus is not so easy as you think, but there is a lot of info on the web about it, tutorials, etc go to the vray site and look under the tutorials chapter, there is a couple of good vray network tutorials Link to comment Share on other sites More sharing options...
Hoa Dinh Posted November 12, 2007 Share Posted November 12, 2007 http://www.spot3d.com/vray/help/150R1/distributed_rendering.htm maybe can help you Link to comment Share on other sites More sharing options...
angus Posted November 14, 2007 Author Share Posted November 14, 2007 I got it, thank you very much for your help guys appreciate it Link to comment Share on other sites More sharing options...
