Eric Posted August 5, 2002 Share Posted August 5, 2002 Hello all! This is a sorta long post, but I'd REALLY appreciate any help the group might be able to offer. I'd like to see if I can get some input from the group on a VIZ4 lighting study animation. I'm using both sunlight and fixed lighting (about 200 various fixed and spot lights) for a commercial retail exterior model. The sunlight is animated from dawn to dusk, with the lights being the primary lighting at dusk. I'm not up for selecting every light (~200 of them) and turning each of them on at about the start of dusk in the animation, but I can't seem to find a way to turn them all off at once. I thought I would try grouping them and doing a visibility track, but that didn't work when I rendered it. What's the trick to turning multiple lights on and off in the track with just a few clicks, rather than probably an hour's worth of time activating each one individually? Also, how do I coordinate the background color with the real-world color of the sky in relation to the time of day? Is there a setting that changes the background color in relation to the sunlight position/time of day? One final question - I've set the animation to render using radiosity, and to calculate radiosity when required, with automatic exposure control (which looks great when I manually activate radiosity for various frames and render the image), but when I do a full frame-by-frame final redering to individual files, and then walk away for day or two, it doesn't seem like it's re-calculating the radiosity solution. Am I missing something? Once again, any help would be greatly appreciated. Link to comment Share on other sites More sharing options...
nisus Posted August 5, 2002 Share Posted August 5, 2002 Hi Eric, Only a quick answer, unfortunately. I'm not up for selecting every light (~200 of them) and turning each of them on at about the start of dusk in the animation, but I can't seem to find a way to turn them all off at once. --> instance you're lights as much as possible OR copy/instance your settings from one spot to another in trackview Also, how do I coordinate the background color with the real-world color of the sky in relation to the time of day? Is there a setting that changes the background color in relation to the sunlight position/time of day? --> check out Arete's Digital Nature Tools (on www.digimation.com): this plugin changes atmosphere (backgroundcolor, haze etc.) automatically when you animate a sunmove --> max 2.5 users had a lovely plugin called 4E (Four Elements) which was really marvellous for animated skies. Unfortunately Corel bought the software and does not plan to launch it again (as it might be a concurrent to it's bryce...) I've set the animation to render using radiosity, and to calculate radiosity when required, with automatic exposure control --> check the manual on automatic exposure control. (I remember somehow that it's not recommended for animations...) rgds nisus Link to comment Share on other sites More sharing options...
