Billabong Posted November 12, 2007 Share Posted November 12, 2007 This is an apartment for a client, that I'm hoping to get some feedback on. Apart from the curtains. I think the interior decorater was smoking a little wacky weed when sent me this stuff she wanted in there. I was hoping to get some feedback on my lighting and maybe a little help. My bg image is rendering washed out. I have it on a plane just outside the window. Ive tried turning off recieving GI in its vray object properties but that just makes it black and not show up at all, so then i tried turning up the output for it, that just gives me vray errors. So anythoughts on that? Also have a look at the glass right below the fan, its suppose to be frosted glass, but that doesnt look anything like frosted glass to me, here are my vray settings and thanks for looking Adaptive subdivision IM -Med, 60,20 LC-1500,0.01 color mapping is Intensity exponetial Dark multiplier 2.0 Bright" " 1.0 Gamma correction 2.2 A image sampler 3/5 and IM using the VrayLanczosFilter Link to comment Share on other sites More sharing options...
BrianKitts Posted November 12, 2007 Share Posted November 12, 2007 its a great start, the overall lighting has a nice feel. But honestly I can't stop looking at the curtains...... they are degrading the overall quality severly. It's partially the color but they also look like they are very rigid and not hanging freely. A background will help as well. You may want to look for a new texture for the rug. The room is nicely furnished, but the rug looks like grandma sewed it together a hundred years ago. Link to comment Share on other sites More sharing options...
Billabong Posted November 12, 2007 Author Share Posted November 12, 2007 Thanks Brian for replying, I agree I hate those curtains, makes me wanna vommit everytime i look at'em, As for the bg image, do you have any suggestions on how to keep it from washing out? Link to comment Share on other sites More sharing options...
BrianKitts Posted November 12, 2007 Share Posted November 12, 2007 actually it should be somewhat washed out. Pull out your digital camera and take a picture inside with an exterior window in view..... the camera will adjust to the interior lighting levels which will result in a blown out (washed out) exterior lighting level. Reference pictures will aid you in knowing just how far to take it. here's a picture that I just pulled out of a quick google search to illustrate my point.... http://www.northlight-images.co.uk/ecademy/interior.jpg Link to comment Share on other sites More sharing options...
Billabong Posted November 12, 2007 Author Share Posted November 12, 2007 I see what you mean, thanks Link to comment Share on other sites More sharing options...
Stephen Thomas Posted November 12, 2007 Share Posted November 12, 2007 You could try using a vray light material for your background image applied to the plane. This way it will just pump out a constant value unaffected by GI and you can adjust the exposure by increasing the multiplier. Link to comment Share on other sites More sharing options...
Billabong Posted November 12, 2007 Author Share Posted November 12, 2007 Ill give that a try, Thanks Link to comment Share on other sites More sharing options...
wodewil Posted November 13, 2007 Share Posted November 13, 2007 Hello! great materials!!! I've the same problem some time ago and I've put plane with VrayLight on it with texture... but I've get very dark reflections on mirror (painting on the wall in Your case)... so I've manipuleted then in Photoshop later. I'm very curious how You solve it. In Internet are a lot of very nice tutorials for Cloth manipulator - courtains and small gift for all just apply some texture for diffuse http://www.cgarchitect.com/vb/images/attach/zip.gif Very nice picture See You later ...(...)... here's a picture that I just pulled out of a quick google search to illustrate my point.... http://www.northlight-images.co.uk/ecademy/interior.jpg I hope that this is a photo Link to comment Share on other sites More sharing options...
dagor Posted November 13, 2007 Share Posted November 13, 2007 this is a photo )) thay do Commercial photographic services Link to comment Share on other sites More sharing options...
Billabong Posted November 25, 2007 Author Share Posted November 25, 2007 Here is a render of the kitchen, IM getting some strange noise problems, and I cant figure out why. Im using the vray sun, with basically default settings, and I also have a vray light above the kitchen to help with lighting it and two skylight portal lights in front of the sliding glass door. here are my render settings as well. thanks for any help Link to comment Share on other sites More sharing options...
dagor Posted November 26, 2007 Share Posted November 26, 2007 set subpixel mapping and clamp output in color mapping rollout Link to comment Share on other sites More sharing options...
Billabong Posted November 26, 2007 Author Share Posted November 26, 2007 that worked perfectly,I never use sub-pixel mapping, because I always get that warning. once again thank you Danil Link to comment Share on other sites More sharing options...
JoelCallahan Posted November 26, 2007 Share Posted November 26, 2007 Hi Billabong! Fancy running into you here.. hehhe I take photos commercially, and as I learn more and more about ArchViz it seems that a photographer tries to make the house/room look as perfect as possible, but a CG ArchViz tries to make it look as real as possible. It won't look 'real' until it has flaws purposefully placed in the scene. Weird, eh? re: blown out windows - a flash fixes that. Has to do with the way the human eye sees the different levels of light versus the way a camera does. With a multi-exposed image (i.e. f/stop bracketing) you can simulate that. I use Photomatrix and go from 2 seconds to 1/250 of a second with as many stops inbetween as I can, then combine them into a single photo. The result is often better than what a camera takes with a flash. Link to comment Share on other sites More sharing options...
