bmcgonigle Posted November 13, 2007 Share Posted November 13, 2007 I'm having an issue with some glass reflectance. As you can see below where there are several surfaces with the glass material assigned overlapped they darken to a grey. The glass surfaces are made out of boxs with 1/16" thickness and assigned the material. This is a stage/studio type of setup so I'm thinking the environment color is whats coming through but seeing as its in only that small area I was hoping there was a means of changing the reflectance bounce of the material to fix the issue. Any idea? Link to comment Share on other sites More sharing options...
alfienoakes Posted November 14, 2007 Share Posted November 14, 2007 what are your environment settings for reflection and refraction.? Are you using the overide max check box? Link to comment Share on other sites More sharing options...
Fernando Lino Posted November 14, 2007 Share Posted November 14, 2007 it could be IOR and/or depth refraction Link to comment Share on other sites More sharing options...
bmcgonigle Posted November 14, 2007 Author Share Posted November 14, 2007 Andy, thanks for your help. I'm hoping your looking for these settings from the glass material? (I'm still very green to VRay) They are as follows Link to comment Share on other sites More sharing options...
dagor Posted November 14, 2007 Share Posted November 14, 2007 please check it there is only one glass in the trouble place. may ne second glass in subobject... Link to comment Share on other sites More sharing options...
bmcgonigle Posted November 14, 2007 Author Share Posted November 14, 2007 There are actually 2 pieces of glass, one on each side of the frame. So within that red square there are 4 pieces of glass overlapping each other. The pieces of glass are made of box elements with 1/16" thickness to them (so i guess technically we are talking about 8 actual glass faces) Link to comment Share on other sites More sharing options...
ameo Posted November 14, 2007 Share Posted November 14, 2007 Increase the max depth value in reflection and refraction. Link to comment Share on other sites More sharing options...
bmcgonigle Posted November 14, 2007 Author Share Posted November 14, 2007 100 internet points to you ameo! I made the recommended change and my reflectance issue is gone. Thanks very much! Link to comment Share on other sites More sharing options...
alfienoakes Posted November 15, 2007 Share Posted November 15, 2007 There are actually 2 pieces of glass, one on each side of the frame. So within that red square there are 4 pieces of glass overlapping each other. The pieces of glass are made of box elements with 1/16" thickness to them (so i guess technically we are talking about 8 actual glass faces) I would start by simplifying your modeling technique. It looks good, but showing double glazing on frames like that is overkill.. Could save you time and stress. At least you know what max depth does now thou. Link to comment Share on other sites More sharing options...
bmcgonigle Posted November 15, 2007 Author Share Posted November 15, 2007 Yea, that would be great but the model is generated by a cad program in a "true to life" manor so alot of the more irrational bits are included as well (ie. hidden brackets, etc) but the glass panels weren't included for some reason. I redid the glass myself and hind sight being 20/20 I'll surely use single planes for glass in the future. But the knowledge I've gained is worth the mistakes Link to comment Share on other sites More sharing options...
