Changing V-Ray Frame Stamp Data
Claudio Branch
pardon the poor formating, copied and pasted from...
http://www.spot3d.com/vray/help/150SP1/render_params_system.htm#frameStamp
%vrayversion the current version of V-Ray
%filename the name of the current scene file
%frame the number of the current frame
%primitives * the number of unique intersectable primitives generated for the current frame*
%rendertime the render time for the current frame
%computername the network name of the computer
%date the current system date
%time the current system time
%w the width of the image in pixels
%h the height of the image in pixels
%camera the name of the camera for this frame (if rendering from a camera, empty string otherwise)
%"" the value of any V-Ray parameter, given its MaxScript name (see section on MaxScript). Note that you must enclose the parameter name in quotation marks ("). Also note that this option only works when rendering to the 3ds Max frame buffer.
%ram the amount of physical memory (in KBytes) installed on the system
%vmem the amount of virtual memory (in KBytes) available on the system
%mhz the clock speed of the system CPU(s)
%os the operating system
I followed the MaxScript link, but still did not manage to find the information that gives me the proper names for frame stamping LC, QMC or IM values.
