SgWRX Posted November 15, 2007 Share Posted November 15, 2007 i have a window and i noticed when i set GI to on, max. num. of photons per sample set to 1 i see no photons except a few around the frame of the window which appear to be on the outside-side of the window. i have the windows object properties unchecked for cast shadows. if i hide the window, i can see the photons when i render. what did i miss? you can't shoot photons through a window? the material for the window is a multi sub object with arch & design glass (thin walled) template. the main light is a mr area spot. 40000 avg gi photons per light. thanks Link to comment Share on other sites More sharing options...
Justin Hunt Posted November 15, 2007 Share Posted November 15, 2007 chack the objects mentray properties and uncheck generate photons. Generally though if you are using an Arch&Design shader (which I recommend) it has a photon shader built in thus telling mr how that surface will react to photons. If you are not using a A&D or mr shader then drop a photon shader into the photons slot. HTH JHV Link to comment Share on other sites More sharing options...
shaneis Posted November 15, 2007 Share Posted November 15, 2007 Have you connected the photonic attribtes to the material to allow the photons through? On a similar note, photons will pass through the "glass" just as they would in the real world - except in the case of caustic photons. Link to comment Share on other sites More sharing options...
Justin Hunt Posted November 15, 2007 Share Posted November 15, 2007 quick draw shaneis:p JHV Link to comment Share on other sites More sharing options...
SgWRX Posted November 15, 2007 Author Share Posted November 15, 2007 thanks both. will try this tomorrow. gotta get some sleep. Link to comment Share on other sites More sharing options...
shaneis Posted November 15, 2007 Share Posted November 15, 2007 quick draw shaneis:p LOL, guess so! Just hoping I was somewhere on track! See you at the next corral? Link to comment Share on other sites More sharing options...
