Interiors
nhayes
Yep, more like finals. Is everything done in Modo - all models, lighting and rendering?
Yes, all lighting and rendering done in modo. Most of the elements (strcuture,fixings, bed, bath, lamps etc.) were modeled to spec. in modo.
There are a few modified stock items as follows:
Master bedroom: Plant.
Bedroom 2: Diary, small clock, sleeping pillows.
Bathroom: Flowers, leather wash bag, towel.
These images are not that far from finals. Some of the materials need a bit of attention and I want to improve the contrast so will be switching to HDR output and then tone-mapping using picturenaut/photomatrix.
regards,
-neil
  • 4 weeks later...
regards,
-neil
my friend say some article said this thing fast
is it fast man?
how long you take to render your scene
anyway good work man
hope can see the final
  • 1 month later...
nice work mate...can't wait to see finals...whats the time frame and rig setup on your renders:cool:
Sorry for the delayed response as I've been busy working on ther projects.
If you're refering to the lighting rig. It look about 5-10 minutes to get the lighting in place and set the correct exitance values. modo has an interactive render preview (iView) so it does not take long to get the lighting where you want it.
In terms of the lighting I often use a combination of Area Lights and Luminous Geometry. I use these two light types together (at each location, same size) to get the best of both worlds in that I get smooth highlights from the luminous geometry and great soft shadows from the area lights. This is very simple and fast to setup in modo.
-neil
is it fast man?
The master bedroom image was around 6 megapixels (2717 x 2303) this took around 2hrs and 50 minutes on a basic quad core (Q6600). Pretty fast especially considering I used more expensive options in terms of render time, such as:
1. Displacement on the rug, throw, blanket and pillows.
2. Area lights with a high number of samples.
3. All materials set to use physically based shading
regards,
-neil
