Jonny English Posted September 12, 2003 Share Posted September 12, 2003 I am having a problem with using the Architectural Glass script that has been discussed in these Forums... I run it as a script and tweek the settings to create a glass material - that's ok. However after I quit and open the file again the program tells me that the Architectural Glass script has a missing dll. Can anyone help me to try and retain the settings that I might have spent a long time trying to achieve. Cheers, Jonny English. Link to comment Share on other sites More sharing options...
quizzy Posted September 12, 2003 Share Posted September 12, 2003 it would help if you could tell us which dll is missing... Link to comment Share on other sites More sharing options...
Jonny English Posted September 12, 2003 Author Share Posted September 12, 2003 Hi Quizzy The alert just says Missing DLL's - scripted Plugin. Any ideas? Jonny English. Link to comment Share on other sites More sharing options...
Jonny English Posted September 12, 2003 Author Share Posted September 12, 2003 I have solved the problem...I just needed to put the script in the script startup folder, so that it loaded automatically. Jonny English. Link to comment Share on other sites More sharing options...
diablo Posted September 12, 2003 Share Posted September 12, 2003 hi Jonny English,can you tell me where can I find this glass script? thanks. Link to comment Share on other sites More sharing options...
xgarcia Posted September 12, 2003 Share Posted September 12, 2003 Jon Seagull's Architectural Glass Script You can also find it at Script Spot.com ...and yes, place it in your scripts/startup folder in order to load a scene that uses the script properly (otherwise you have to manually run the script each time - annoying). Link to comment Share on other sites More sharing options...
diablo Posted September 12, 2003 Share Posted September 12, 2003 ok thank you guys Link to comment Share on other sites More sharing options...
Scott Erstad Posted September 12, 2003 Share Posted September 12, 2003 hey guys and gals, Would anyone be able to post an example or two of glass rendered with this script? thanks, Scott Link to comment Share on other sites More sharing options...
xgarcia Posted September 12, 2003 Share Posted September 12, 2003 This is one of my school design projects last year. I used the script with blurred reflections. Scene is fakeosity btw. Link to comment Share on other sites More sharing options...
Brink Posted September 18, 2003 Share Posted September 18, 2003 does that script work with Viz or just in Max? Link to comment Share on other sites More sharing options...
xgarcia Posted September 18, 2003 Share Posted September 18, 2003 both. Well I've used it in Viz4 and Max5. I think Mr. Seagull wrote the script for max4. Link to comment Share on other sites More sharing options...
