pailhead Posted November 19, 2007 Share Posted November 19, 2007 I have a .dwg file with a bunch of survey data, and among others, there is a layer containing elevated points. Is there a way to use these points to create something that could later be used as terrain in 3d studio max? Can i create a 3d terrain using these points in CAD itself, or can they be connected with lines somehow, so that they can be converted into terrain in max afterwards. Either is fine. Link to comment Share on other sites More sharing options...
BobM Posted November 19, 2007 Share Posted November 19, 2007 You can join the points with 3D polyines and from them create a a mesh of the whole terain. BobM Link to comment Share on other sites More sharing options...
pailhead Posted November 22, 2007 Author Share Posted November 22, 2007 The thing is VERY dense, i'm not sure if this is the right way to go, it would take countless hours to achieve this. I'm sure that there is a solution for this, but it may be that some sort of a plugin is needed. Link to comment Share on other sites More sharing options...
Claudio Branch Posted November 23, 2007 Share Posted November 23, 2007 pailhead said: The thing is VERY dense, i'm not sure if this is the right way to go, it would take countless hours to achieve this. I'm sure that there is a solution for this, but it may be that some sort of a plugin is needed. There is a very good solution for your problem. EasySite is an AutoCAD plugin that you can demo for 15 days for free. It sells for $495. http://www.cadeasy.com/ I use it on all of my large-scale terrain models because it makes the process easier and even enjoyable. PM me if you want to see/learn more... Link to comment Share on other sites More sharing options...
