Backburner not detecting one server..!!
djoshi
I have setup backburner on three machines, One of the server is not getting detected in network job assignment palette. It registers to manager, Manager also shows it,
server & manager pinging each other properly.
I am not sure where it is going wrong...:confused:. I have tried putting manual IP add. etc..but..nothing works..! Only two servers shows in list..!
If anybody knows.. what to do..pls. let me know..!
Have you tried not doing an automatic search in the settings but explicitly putting in the manager's IP address?
Also - is that IP subnet correct (not saying it isn't). 255.255.0.0 is generally used on 10.x.x.x networks whereas typically smaller networks use 192.168.x.x which use a 255.255.255.0 subnet - might be worth comparing with the settings on your slaves that are working.
when I checked in ipconfig it shows 255.255.0.0 so I kept that, infect when I put it on auto search it takes 255.255.255.0. Actually both works on other two machines. I have tried both on that third machine but...:rolleyes:
As I have said it is pinging properly in manager & server massage windows from all the machines..only one is not listing in job assignment window.
I think so all machines are communicating properly, Something is wrong in 3d max setting..not detecting that machine ...not sure..:confused:
