Generate Posted November 19, 2007 Share Posted November 19, 2007 Its not a error that shows up in the log but this is the issue. I have 8 computers on the network setup to use as a server these are machines that people are currently using but nothing real processor intensive. The spawner on all of them is running and I have tested each machine with a single rendering to each using Vray with perfect success. This is where the issue happens When I set up the distributive rendering with all 8 of the servers connected and ready, when I hit render there are no errors or warnings that show up in the Vray message log. All that said when it renders it has missing maps in the some of the buckets so I end up with a spoty rendering. I have a hunch that its a network traffic or latency issue any suggestions? Link to comment Share on other sites More sharing options...
Devin Johnston Posted November 19, 2007 Share Posted November 19, 2007 Make sure all of your maps are accessible to all machines using the UNC path to map your materials. That is usually the biggest contributor to missing buckets. Link to comment Share on other sites More sharing options...
Generate Posted November 19, 2007 Author Share Posted November 19, 2007 problem solved, I.T. guy had a brain fart and the server path is fixed. Thank you. Link to comment Share on other sites More sharing options...
