Over Saturated maps
Renderman
I have been trying to figure out how to reduce the saturation of some of my maps on my GI renderings. The map images look fine in Photoshop. I have reduced the rgb level in the output rollout for the map with varying results. Short of reducing the saturation of the map in Photoshop (what a drag!), is there a proper way to do this? Anybody else having the same problem? Any other comments or sugestions on the image are greatly appreciated.
I'm having a similar problem. I'm posting a pic of the rendering untouched in photoshop, and a reduced size copy of the material I'm using.
The material swatch is actually the same material as on the main feature panel inset - the orange colored panel.
I'm using a radiosity override material on it with:
Reflectance Scale: 0.5
Color Bleed: 0.0
Transmittance Scale: 1.0 (which could probably set to 0.0)
Luminance Scale: 0.0
Indirect Light Bump Scale: 1.0
The actualy material properties are:
2-sided (because it's faces brought in from Autocad)
Ambient: Black
Diffuse: The Pionite Sugar Maple swatch
Bump: Amount 15 - Noise (defaults with size of .08)
Specular Level: 91
Glossiness: 61
Soften: 0.5
Blinn Shader
Eric-
Here's another view of my project which illustrates the same problem you seem to have with your wood panel. My panels don't even show the wood grain and are over saturated. I have posted my settings as well. I hope someone can shed some light on this issue. Did you try lowering the rgb output of your diffuse map?
Good luck.
http://www.cgarchitect.com/forum/filepush.asp?file=South.jpg
http://www.cgarchitect.com/forum/filepush.asp?file=LightPanels.jpg
http://www.cgarchitect.com/forum/filepush.asp?file=MaterialEditor.jpg
