WAcky Posted November 22, 2007 Share Posted November 22, 2007 Well just days after my singing praises about max 2008 64 i've hit a rather major problem. Ive rendered out a scene with 16million triangles after retessellation as its telling me in the mental ray message window. I am aware that this is a ridiculous amount of polys but the thing that gets me is that max doesnt crash before or during rendering but after cleanup?! 95% of this is because of foliage and of course there are ways I will have to work around this by using render passes and so forth, but if my computer has the power to render these things out, then why the hell is it crashing after its done all the hard work...how confusing... I have tried adjusting pretty much everything in the render settings to no avail. Tried saving smaller FG maps and reading from them. Tried the memory saving options on and off etc. The error is the basic blah blah max will try and save a backup file Ok or Cancel. So yeah, if anyone else finds a solution let me know! Link to comment Share on other sites More sharing options...
robkar97 Posted November 22, 2007 Share Posted November 22, 2007 My memory problems (in the form of black buckets when rendering with mental ray) was remedied by using Backburner and turning off the "rendered frame window"... don't know if this is relevant for your problem, but I have made it a habit to use Backburner for complex scenes Good luck, Robert Link to comment Share on other sites More sharing options...
WAcky Posted November 23, 2007 Author Share Posted November 23, 2007 Hi, Surely i will use a method like this for the final renders, but even a 4 minute render crashes! I will have to do some reading on Backburner as i haven't touched it before. Thanks for the suggestion Link to comment Share on other sites More sharing options...
Tommy Burns Posted February 5, 2008 Share Posted February 5, 2008 A colleague of mine at the moment has this problem with mental ray It renders totally and then when it goes to storing frame it crashes Someone must have a fix for this or is it a bug. Like Wacky we have tried literally everything we can think off. I had the same problem a while ago myself and I fixed it by merging into a new scene but this time its not working at all. Link to comment Share on other sites More sharing options...
WAcky Posted February 5, 2008 Author Share Posted February 5, 2008 Ive been having a wonderful time with max over the last few days with persistent crashing. Im about to go f'ing postal. I had some RPC's in my scene which turned out to be the problem. They were working fine until this problem popped up again so i took out the RPC's. didnt fix the problem. I then reverted back to a previous file and max crashed. Turns out every file with this one RPC is for some reason now corrupted. About 20 hours of work gone because these files cant be opened. I didnt try a merge. Didnt think of that... Either way i still dont know why this happens. Something really needs to be fixed with this program. I've not yet dealt with a scene that doesnt have a crash tantrum in one scene or another. I'm trying to start a business and I'm using this product that is totally unreliable. Link to comment Share on other sites More sharing options...
Tommy L Posted February 5, 2008 Share Posted February 5, 2008 UNinstall the rpc plugin and see if it works. Link to comment Share on other sites More sharing options...
robkar97 Posted February 5, 2008 Share Posted February 5, 2008 Have you tried doing the rendering via Backburner without the framebuffer? It is a longshot, but it solved my issues with mental ray. You said you haven't used it, but it's really quite simple. Just start all three programs in the Backburner folder (same as 3ds max from the start menu) then check [x] Net render, connect to the manager and submit the job. Robert Link to comment Share on other sites More sharing options...
WAcky Posted February 6, 2008 Author Share Posted February 6, 2008 All my scenes just wont start with backburner. Im going to do some testing tonight on some simple scenes to diagnose the problem but yes i will def try backburner....if i can get it to work Link to comment Share on other sites More sharing options...
jinsley Posted September 15, 2009 Share Posted September 15, 2009 James, Did you ever figure this out? Did Backburner help? Having the same problem this week, merged scene into new file and it helped, but now it is back and nothing is fixing it... about to lose my mind. Link to comment Share on other sites More sharing options...
WAcky Posted September 16, 2009 Author Share Posted September 16, 2009 Stopped using RPC's I think Link to comment Share on other sites More sharing options...
jinsley Posted September 16, 2009 Share Posted September 16, 2009 Stopped using RPC's I think dahm RPC! not using them though... maybe too many MR proxies... Thx for the answer. Seems to be fine now after removing some grow ivy objects... -JI Link to comment Share on other sites More sharing options...
WAcky Posted September 16, 2009 Author Share Posted September 16, 2009 Interesting. I'm using GrowIvy for the first time in a job atm... Link to comment Share on other sites More sharing options...
jinsley Posted September 16, 2009 Share Posted September 16, 2009 I think it is very easy to get very high poly counts really fast with the guruware grow ivy... keep the smooth option unchecked unless it is necessary... Link to comment Share on other sites More sharing options...
