thumbnails not appearing
Guest nazcaLine
Guest nazcaLine
recently i installed max 2008, and before that i removed my max 8.
thing is that all my .max files don't show up in the max logo, and when i want to setup "always open this file with this program" max just doesn't appear in the list. so all my max files appear like an unknown file archive, i can't see thumbnails, it's frustrating. i have no problems opening and working with the files, though.
any idea about this? what can i do?
Eduardo
Eduardo
Here is the fix. Create a new text file and name it thumbnail.txt
Copy this text into the file.
Windows Registry Editor Version 5.00
[HKEY_CLASSES_ROOT\.max\ShellEx\{BB2E617C-0920-11d1-9A0B-00C04FC2D6C1}]
@="{9DBD2C50-62AD-11d0-B806-00C04FD706EC}"
Now rename the file thumbnail.reg. Right click on thumbnail.reg and select merge. Your thumbnails will now be displayed inside of windows explorer. If you have the same problem with Photoshop let me know. I could email you the fix for that as well.
Hope this helps you out.
Guest nazcaLine
Rick:
the problem is that max doesn't appear in the program list. it's impossible that it isn't there! i'm working in max right now!
any other suggestion, idea? please...
grant:
thanks for your help, i'll try that as a last option. i think there has to be something more simple for this....
Eduardo
Rick:
If its not on the list then click the 'Browse' button and browse for your 3dsmax.exe file - that will associate the .max extension with the correct application.
Guest nazcaLine
matt: i did exactly that. thing is that nothing happened, max just doesn't appear in the list. it's so annoying!!!
thanks for your help though
Eduardo
Eduardo
You're saying that when you browse for 3dsmax.exe in your MAX installation directory its not there? That's just not possible. I'm not talking about the list of named programmes that opens up first - at the bottom of that window there is a Browse button that lets you pick any .exe on your system.
Guest nazcaLine
yes, i looked for with that browse button, and the 3dsmax.exe IS THERE, thing is that when i pick the .exe, and click "open", nothing happens. max just won't appear in the list. strange, huh?
another case for the X-files...better say, maX-files...:D
Eduardo
I assure you it is possible, and I'm with NazcaLine it drives me nuts. Not nuts enough to have blind faith in the operability of Windows mind you, but it does hamper the work flow.
Guest nazcaLine
yup, something happens here...as i say, the max.exe file is there, it's just that when selected, it doesn't appear in the list. it's so annoying, i can't see the thumbnails in the explorer!!!
Eduardo
Have you tried going through Windows Explorer>Tools>Folder Options>File Types? Scroll to the Max file extension and either assign or reassign the 'opens with'. If the Max extension is not listed, then you can add it with the 'new' button.
Guest nazcaLine
nop, it doesn't work, by the way, i've noticed also that flash CS3 doesn't appear in the list either. and guess what...i had flash 8 installed before, installed flash cs3 and uninstalled flash 8...looks like there's a problem when uninstalling previous versions and getting new versions...it seems that windows doesn't "recognize" the new program to open the old files...because the old program is "missing"...doh...
Eduardo
