Justin Hunt Posted November 23, 2007 Share Posted November 23, 2007 ---------------------------------------------------------------- Revit File Linking control ---------------------------------------------------------------- More / better control of how Revit models are File Linked into Max --------------------------------------------------------------- DETAILED DESCRIPTION --------------------------------------------------------------- Having the ability to control how Revit models are imported into Max will make handling Revit models more efficient. It is inefficient to have every element of a Revit model as individual elements and as a block in Max. I'd rather have like elements brought in as one object, such as all the glass panes in a curtain wall as one object, the mullions as an other and the frames as an other. If I want to separate then then leave it to me to do it manually. --------------------------------------------------------------- WHY THIS REQUEST IS IMPORTANT TO YOU --------------------------------------------------------------- Max is notoriously bad at handling 10000's of individual objects. Simplifying the object count makes navigation and rendering faster and less prone to crashing. Link to comment Share on other sites More sharing options...
DapperDanJelly Posted December 27, 2007 Share Posted December 27, 2007 I second you in this request. I'd like to see this tool in a new release if it's not in 2008 (I'm currently using Max9) with Autocad and Revit. Link to comment Share on other sites More sharing options...
