ns_darth Posted November 30, 2007 Share Posted November 30, 2007 Hi! I have problem with noise when I use V-ray light in interior. I tried to solve it increasing gl. sub. but render time goes high. Do you have any advice? tnx Link to comment Share on other sites More sharing options...
STRAT Posted November 30, 2007 Share Posted November 30, 2007 what noise is it? reflection noise, area shadow noise etc etc. isolate what noise it is an locally add more samples to the offending emitter. Link to comment Share on other sites More sharing options...
ns_darth Posted December 1, 2007 Author Share Posted December 1, 2007 you mean to rise subdivision on every v-ray light. I'll try that. tnx Link to comment Share on other sites More sharing options...
Cortex Posted December 1, 2007 Share Posted December 1, 2007 Try to lower Color Thr in QMC/DMC ! 0.01 or 0.005 Link to comment Share on other sites More sharing options...
sile Posted December 1, 2007 Share Posted December 1, 2007 Don't go lower than 0,01 if you use V ray 1.5 R3 or higher. It could be few things. Could you post your rendering? What do you use as primary/secondary bounce of GI? If you use QMC(brute force) you need very high number of subdivision...but that will slow down render time significantly. Link to comment Share on other sites More sharing options...
ns_darth Posted December 3, 2007 Author Share Posted December 3, 2007 I used irr. map: -3,0: HSph sub/ interp samp 60/30: Clr tresh 0.2: Nrm tresh 0.1 light cache: subdiv 1000: sample size 0.02 After I increase Gl. subdivision in rQMC on 2 I got this. And these dark areas... Link to comment Share on other sites More sharing options...
Hoa Dinh Posted December 3, 2007 Share Posted December 3, 2007 maybe you use "store IR map" for vraylight. unstick it and increase vraylight subdiv, maybe 20-25 Link to comment Share on other sites More sharing options...
sile Posted December 3, 2007 Share Posted December 3, 2007 thanks for posting pic. increasing v ray light subdivs is always good option. But that will increase render time significantly. Also try to set adaptive amount to around 0.6(in rQMC (DMC) sampler rollout) By dafault is is 0.85. Here is the link for all V ray explanations: www.spot3d.com Link to comment Share on other sites More sharing options...
ns_darth Posted December 4, 2007 Author Share Posted December 4, 2007 tnx for tips. No, store with IR map was off. I'll try to improve the work. Hope I'll have time. And tnx for the link. Link to comment Share on other sites More sharing options...
