steve Posted August 1, 2003 Share Posted August 1, 2003 Hi, I am new with radiosity and have tried some interior renderings where the floor marble with little reflection came out with washed out texture.Any hint please.Thanks Link to comment Share on other sites More sharing options...
Arnel Posted August 1, 2003 Share Posted August 1, 2003 Post a sample image for us to be able to guide you in the right direction. Link to comment Share on other sites More sharing options...
Munz Posted August 1, 2003 Share Posted August 1, 2003 I had the same problem, could not get the rich colors in the marble to show with radiosity. I gave up and turn the radiosity off... Anyone have any ideas? Link to comment Share on other sites More sharing options...
STRAT Posted August 1, 2003 Share Posted August 1, 2003 Originally posted by Munz: I had the same problem, could not get the rich colors in the marble to show with radiosity. I gave up and turn the radiosity off... Anyone have any ideas? lol, yeah, learn it! Link to comment Share on other sites More sharing options...
arch83 Posted August 1, 2003 Share Posted August 1, 2003 Yeah well "learn it" is always sound, although not very helpful advice. The Viz radiosity tutorials are pretty well hidden. Open the tutorials in Viz and go to Land Planning>Adding Daylight (it's in there ) You can also read an intro on getting started HERE Here is a link to a .pdf tutoral prepared by Ted Boardman from a Las Vegas seminar from Autodesk University that I found in my links. HERE That should at least be somewhat helpful. Jeff [ August 01, 2003, 03:28 PM: Message edited by: arch83 ] Link to comment Share on other sites More sharing options...
xgarcia Posted August 1, 2003 Share Posted August 1, 2003 ---edit---zip taken down for webspace - sorry Xavier [ September 30, 2003, 11:27 AM: Message edited by: xgarcia ] Link to comment Share on other sites More sharing options...
steve Posted August 3, 2003 Author Share Posted August 3, 2003 This is my sample scene.The floor marble looks washed out and the glass table doesn't look transparent.I added indirect lighting using radiosity override material which only showed with no exposure. Using logaritmic exposure seems to illiminate this light effect.Any advice ?http://www.cgarchitect.com/forum/filepush.asp?file=TEST-RADIOSITY-DAY3-regather31h-sm.jpg http://www.cgarchitect.com/forum/filepush.asp?file=TEST-RADIOSITY5-sm.jpg Link to comment Share on other sites More sharing options...
steve Posted August 3, 2003 Author Share Posted August 3, 2003 Sorry, this is my daylight test image http://www.cgarchitect.com/forum/filepush.asp?file=TEST-RADIOSITY-DAY3-regather31h-sm.jpg Link to comment Share on other sites More sharing options...
Lightning Posted August 4, 2003 Share Posted August 4, 2003 Have you tried using the Radiosity override material for this problem? Link to comment Share on other sites More sharing options...
Fran Posted August 4, 2003 Share Posted August 4, 2003 Hi Steve, What are your exposure control settings? Make sure Daylight is checked. See if adjusting the Physical Scale helps. Also try reducing Brightness. Another thing to try is RGB Output settings for your bitmaps. Lastly, you might have to reduce the saturation of your bitmaps in Photoshop (or other). Nice scene, BTW. Link to comment Share on other sites More sharing options...
