nivvu Posted December 5, 2007 Share Posted December 5, 2007 hi all.... when i render a scene After using hair and fur modifier to create grass for the ground...the image gets cut around the boundaries of the rpc's and 2dimages placed on the ground..........can anyone tell y its happening and what i have to do to get rid of this:confused:....thanks in advance cheers nivas. Link to comment Share on other sites More sharing options...
kippu Posted December 5, 2007 Share Posted December 5, 2007 i would imagine that to be because they are acting as billboards and fur is going around them.... btw once i read the topic i thought it had something to do with racism and stuff Link to comment Share on other sites More sharing options...
nivvu Posted December 5, 2007 Author Share Posted December 5, 2007 thanks maria prem....but wat is the solution to avoid this thn...... cheers nivas Link to comment Share on other sites More sharing options...
Ricardo Eloy Posted December 5, 2007 Share Posted December 5, 2007 The problem is not with V-Ray, it's about the Hair and Fur. It won't appear thru opacity maps unless you turn it into geometry. Link to comment Share on other sites More sharing options...
nivvu Posted December 5, 2007 Author Share Posted December 5, 2007 Hi Rick.. Please find the image attached ....as u said i have changed the rectangle to mesh....but still same output....and how to change rpc into mesh.......any ideas?????? cheers nivas Link to comment Share on other sites More sharing options...
Ricardo Eloy Posted December 5, 2007 Share Posted December 5, 2007 No, it's not the props you have to turn into geometries... it's the hair and fur. Check its dialog and you'll see Hair Rendering Options > Hairs > Geometry. But keep in mind it'll take forever to render. Link to comment Share on other sites More sharing options...
nivvu Posted December 5, 2007 Author Share Posted December 5, 2007 ok..ok....thanks rick.....cheers nivas Link to comment Share on other sites More sharing options...
RyanSpaulding Posted December 5, 2007 Share Posted December 5, 2007 Personally, I'd really try to have an RPC-less workflow. Link to comment Share on other sites More sharing options...
jophus14 Posted December 5, 2007 Share Posted December 5, 2007 Why not just add the people and trees in your scene using Photoshop after rendering? Link to comment Share on other sites More sharing options...
