ZFact Posted December 6, 2007 Share Posted December 6, 2007 Need help choosing a graphics card... the machine will be used for modelling, rendering and some graphic design work... it may well be used for realtime wrok further down the line also... whats the best card out there for this in terms of value for money? Thanks Link to comment Share on other sites More sharing options...
AJLynn Posted December 6, 2007 Share Posted December 6, 2007 nVidia 8800GT. It's actually faster than the GTS despite being cheaper and using less power. Link to comment Share on other sites More sharing options...
ZFact Posted December 6, 2007 Author Share Posted December 6, 2007 nVidia 8800GT. It's actually faster than the GTS despite being cheaper and using less power. thanks man Link to comment Share on other sites More sharing options...
ZFact Posted December 6, 2007 Author Share Posted December 6, 2007 What do you think of this card? slightly more expensive but is it worth it?? nvidia GeForce 8800 Ultra 768mb Link to comment Share on other sites More sharing options...
AJLynn Posted December 7, 2007 Share Posted December 7, 2007 It's going to do the same thing but a bit faster. If that's worth it to you, go for it. Link to comment Share on other sites More sharing options...
ZFact Posted December 7, 2007 Author Share Posted December 7, 2007 someone mentioned that i should be thinking about quadros... what would you opinion be on these... too expensive?? Link to comment Share on other sites More sharing options...
AJLynn Posted December 7, 2007 Share Posted December 7, 2007 Depends what software you're running. ...? You use Cinema, right? A Quadro will run Cinema faster, but it costs a lot. Also, it needs to be one of the higher end Quadros to beat an 8800. Link to comment Share on other sites More sharing options...
ZFact Posted December 7, 2007 Author Share Posted December 7, 2007 ok.. i think i'll run with the 8800 then... thanks Andrew Link to comment Share on other sites More sharing options...
AJLynn Posted December 7, 2007 Share Posted December 7, 2007 Funny story. I've got a motherboard problem and I'm waiting for a fix. I have full res, full bit depth video using the VgaSave driver only - my screen looks fine but it has no 2D or 3D acceleration at all. Everything involving the display is incredibly slow. Except for ADT. The menus are slow, the layer pulldown is really slow, but everything involving the drawing area is almost as fast as it usually is. Apparently AutoCAD is the only modern program that doesn't require a video card. Link to comment Share on other sites More sharing options...
Dave Buchhofer Posted December 11, 2007 Share Posted December 11, 2007 yea, by default autocad isn't even accelerated.. unless you go pretty deep into the options and tell it specifically to be! Link to comment Share on other sites More sharing options...
