How to solve this [Daylight] problem?
adamantine
Hello all,
Attached is my self explanatory problem. I would like to have sky and tree outside the window to be not ridiculously bright. Draft render with FG and GI enabled Mental ray with daylight system (mr sky and mr sun) with logarithmic exposure control (exterior daylight off).
Thank you!!!
Thank you guys!
First I want to point out that this is a draft rendering (low FG, and 10000 GI, I think). Before I left office I didn't have time to render high quality, so..
I should have done more explanation, my mistake.
Yes it may have modeling errors, straight import from Revit, but when I render high quality (like i bump up the numbers) the render got much better and the modeling errors do not cause too much blotchy light leaks.
The problem I want to point out is the bright outside light. If I set "exterior daylight" to ON, the outside light is OK but the interior become almost black, when I turn it off, vice versa (like in that attached picture above). I would like to have both interior and outside view at a reasonable brightness.
I don't remember the settings, I'll post tomorrow from office.
Regards
