maxs Posted December 7, 2007 Share Posted December 7, 2007 hi, i have a problem, when i push the "get material button" in the mat editor, the "material/map browser" window doesn`t appear. had the same problem some time ago in max 8, with the "render scene" window. solved it with your help by removing the 3dsmax. ini file and restarting max. tried the same with max 9 now, but found no 3dsmax.ini in the 3dsmax directory. thanks for your suggestions. Link to comment Share on other sites More sharing options...
Matt Clementson Posted December 7, 2007 Share Posted December 7, 2007 The 3dsmax.ini for MAX 9 and above is found in your user profile in the sub directories under C:\Documents and Settings\USERNAME\Local Settings\Application Data\Autodesk\3dsmax\ Link to comment Share on other sites More sharing options...
maxs Posted December 7, 2007 Author Share Posted December 7, 2007 thanks matt, found the 3dsmax.ini, removed it to the desktop, and restarted max, but still the material map browser does not appear. found a lot of infos about lost mateditor windows, and how to make it visible, for example method with "m, alt, left, up....etc." http://www.maxforums.org/thread.aspx?tid=355602 i would like to try it this way, but coul not find out the shortcut for the material/map browser, please help. Link to comment Share on other sites More sharing options...
gfa2 Posted December 7, 2007 Share Posted December 7, 2007 Hit the 'M' key to bring up the material editor. Link to comment Share on other sites More sharing options...
maxs Posted December 7, 2007 Author Share Posted December 7, 2007 i have lost the material/map dialog, the mateditor is here! therefore i need the shortcut - if one exists - for the material/map dialog. Link to comment Share on other sites More sharing options...
maxs Posted December 7, 2007 Author Share Posted December 7, 2007 handeled it with a tip. "you dont need a keybaord short cut for the window if you have the button on the screen, just press it to open the material browser (even if you cant see it) then hit Alt, Spacebar, then go down the 'move' and use the cursor keys, (hitting spacebar saves you having to do all that up-left nonsense :)" Link to comment Share on other sites More sharing options...
masg45 Posted July 26, 2008 Share Posted July 26, 2008 thankes Link to comment Share on other sites More sharing options...
amer abidi Posted July 27, 2008 Share Posted July 27, 2008 hey max, i have the same problem..usually solve it with the alt left down down enter workaround, but surely there must be a proper solution for this?! Link to comment Share on other sites More sharing options...
Crazy Homeless Guy Posted July 27, 2008 Share Posted July 27, 2008 hey max, i have the same problem..usually solve it with the alt left down down enter workaround, but surely there must be a proper solution for this?! that is the proper solution, the other methods listed are work arounds. this typically happens when you are working on 2 monitors and switch to one, or you change to a lower resolution when you were working in a higher. your window is just off screen, and you need to ring it back in. i have accidentally moved a window off screen without switching monitors or resolution, but it isn't that easy. Link to comment Share on other sites More sharing options...
