how to convert .png to .avi
murtazasimari
hii guys
i am preparing one walk through but in my view the camera is moving very fast i tried from so many ways but i didnt find any solution. i found one solution on a net & its written
The animation was first rendered out to .png images, and then compiled into an .avi. That way, you won't lose all rendered frames if something goes wrong in the middle of the rendering... and also you can play with the compression settings later.
but i donno how to convert .png to .avi
plz help me....:confused:
Most post-production tools like Premier or Combustion can take all of your image files (in your case, png's),combine them in a sequence or 'clip', then allow you to output as an .avi file. The avi itself does nothing to slow down your sequence, but the program itself will have the ability to slow your clip with a time tool. Think of it as applying a 'slow motion' effect to your clip.
The problem is that unless you output at higher than 30fps from Max, you'll get jerky playback in your 'slow motion' effect.
