yudk Posted December 10, 2007 Share Posted December 10, 2007 Hi guys.. i had a little problem in using 3d models. I putted some 3d arch model trees in my scene..about 5 trees. and putted some more 3d arch model hedges.but when i rendered it. it have a crash issues... Can anybody help me how to make a low usage memory when using many tree models ? tq so much Link to comment Share on other sites More sharing options...
Spooner04 Posted December 10, 2007 Share Posted December 10, 2007 You need to look into using proxy's. http://www.spot3d.com/vray/help/150SP1/vrayproxy_params.htm Link to comment Share on other sites More sharing options...
yudk Posted December 10, 2007 Author Share Posted December 10, 2007 Yes i've ever heard about this one.. vray proxy. but i still a little bit confused in using it? is it must a in file .mesh?? so i must open my tree file? and change it into .mesh with vray proxy?? am i correct? Link to comment Share on other sites More sharing options...
yudk Posted December 10, 2007 Author Share Posted December 10, 2007 i've tried and it's succeed thank you jeremiah for your reply.. but now i had a little problem with how i can put the materials into my object? because if i make it into .mesh. the objects will become 1.and it was hard to put any material in it...especially with different materials... Link to comment Share on other sites More sharing options...
manta Posted December 10, 2007 Share Posted December 10, 2007 Use the eyedropper in the material editor to extract the materials from the original tree, and then apply them the the proxy, the proxy will retain the original mapping coordinates... Link to comment Share on other sites More sharing options...
Spooner04 Posted December 10, 2007 Share Posted December 10, 2007 We have had success with assigning material I.D.'s to the mesh before we make it a proxy. the mesh will hold these I.D.'s once it is proxied out. You can then assign a multi/sub-object material material to the proxy in the new file and it should work just fine. Link to comment Share on other sites More sharing options...
