smr_VIZ Posted December 10, 2007 Share Posted December 10, 2007 I am an newbie. Here is my first test rendering. I put the glass curtain wall and some basic lightings in the max drawing. The setting is based on what I understands so far but definitely not accurately. The image coming out is too dark and with many dots. I just don't know why. I here attached my image. Hopely you guys can give me some basic comments so I can improve this rendering right away. Thanks a million, Link to comment Share on other sites More sharing options...
AJLynn Posted December 10, 2007 Share Posted December 10, 2007 That looks like an IRMap pass, not a render. Are you using Don't Render Final Image, or whatever they're calling that these days? Link to comment Share on other sites More sharing options...
Ricardo Eloy Posted December 10, 2007 Share Posted December 10, 2007 Turn off Show Samples under Irradiance Map. Link to comment Share on other sites More sharing options...
hushbrown Posted December 12, 2007 Share Posted December 12, 2007 i have also problems in my image it seems reflecting the grass.... Link to comment Share on other sites More sharing options...
Ricardo Eloy Posted December 12, 2007 Share Posted December 12, 2007 First, you might want to start a new thread for your own questions, mate... Second, take a look at your AA filtering and at the VRayMtlOverride for the grass issue. Link to comment Share on other sites More sharing options...
STRAT Posted December 12, 2007 Share Posted December 12, 2007 and turn the saturation down Link to comment Share on other sites More sharing options...
hushbrown Posted December 12, 2007 Share Posted December 12, 2007 how can i start a new thread sir?? i wanted to but i dont know... im only a newbie here. thank you. Link to comment Share on other sites More sharing options...
STRAT Posted December 12, 2007 Share Posted December 12, 2007 how about a bit of thought? click into the forum you want to go to, then click NEW THREAD Link to comment Share on other sites More sharing options...
hushbrown Posted December 12, 2007 Share Posted December 12, 2007 thank you... Link to comment Share on other sites More sharing options...
smr_VIZ Posted December 17, 2007 Author Share Posted December 17, 2007 Rick Eloy said: Turn off Show Samples under Irradiance Map. Thanks, Rick. That is exactly what cuased me the problem. Now, I have better rendering pictures, but the image is not clear no matter how I adjust the Image sampler. This is kind of sad too since I never experienced the same problem in MAX before. I always can produce sharp image with some changes in antiliasing. I guess this would be another setting I forgot to turn on or off? Link to comment Share on other sites More sharing options...
Ricardo Eloy Posted December 17, 2007 Share Posted December 17, 2007 Post your settings and we'll see what's wrong (or not)... Link to comment Share on other sites More sharing options...
smr_VIZ Posted December 18, 2007 Author Share Posted December 18, 2007 Rick Eloy said: Post your settings and we'll see what's wrong (or not)... Hi, Rick. here is the image. In max file, I deleted a lot of details, so if you see that is not a complete building, please don't be surprised. I didn't model this building. The problem I have is not be able to create a sharp image, and the reflection on the glass is not good. If I put up a sphere to represent the sky, then file will take 10 minutes to render such a simple scene, I think again there is some settings I didn't do it right. What should I change? Thanks for the help, rick. Link to comment Share on other sites More sharing options...
smr_VIZ Posted January 2, 2008 Author Share Posted January 2, 2008 Hi, all: I figured out that the problem with my image is sth related to the image sampling settings. Now I want to shift my focus on the VRay materials. My first q would be the material for the glass. So the reflectiona and transparency issue is the key point I need to tackle right now. I wonder if anyone know a link for explaining the parameters inside the material settings? Does Vray material really can produce convingcing glass materials? ANyone can convincing me for this issue? Link to comment Share on other sites More sharing options...
