Uplighter problem
Stephen Thomas
I can't for the life of me figure this one out! As you can see from the image the uplighter seems to be getting cut off by something, while the downlighter is fine. I've tried changing from spots to IES, turning the lights through 180 degrees, remaking the wall geometry, changing the camera view. All with no effect. There is no hidden geometry there so what could it be? This is driving me nuts!! :mad:
Can anyone shed any light on the problem (pardon the pun). ;)
and without camera correction?
Works fine without, but I already have the shot set up and its been approved. Quite a tall lobby space so can't really lose the correction and still show everything I want to. Just adding some lights next to the lift as chosen by the architect, but keep running into this problem.
Iv had exactly the same problem with camera correction in the past....took me ages to work out what it was. I didn't find a way around it.
I also sometimes get 'bent reflections' i.e at 15 degrees from vertical when using camera correction
Finally sorted it! I had Max-compatible shade context box checked in the system rollout. Should have noticed the error message before.
