Mario Pende Posted December 11, 2007 Share Posted December 11, 2007 Hello! I have this exterior project coming soon, and decided to give MW a shot. I have lots of windows and balcony doors in the scene, so I was wondering if the method I used so far for glass modeling, also applies to MW. What I have are 2 meshes, one facing out and one towards the room. Will this work, or I have to do something other to get nice looking glass in MW? Thanx Link to comment Share on other sites More sharing options...
Devin Johnston Posted December 11, 2007 Share Posted December 11, 2007 Your glass has to have thickness it can't be just a plane. You say your using meshes I sounds like you have two planes in which case it might work, Maxwell really need for there to be a thickness between the front and back of the glass in order to simulate glass properly. Link to comment Share on other sites More sharing options...
Mario Pende Posted December 12, 2007 Author Share Posted December 12, 2007 But then I would have overlaping surfaces, because the glass "thickness" plane would overlap with door surface. p.s. open the picture I attached, youll see more clearly highlited glass planes Link to comment Share on other sites More sharing options...
Devin Johnston Posted December 12, 2007 Share Posted December 12, 2007 The easiest way to see if it's going to work is to put a glass material on it and render. Link to comment Share on other sites More sharing options...
Mario Pende Posted December 12, 2007 Author Share Posted December 12, 2007 Yeah, but lets not forget how fast would that be :D Any recomemndation on the glass material from the MW material site? Link to comment Share on other sites More sharing options...
calpolyarc Posted March 19, 2008 Share Posted March 19, 2008 Maxwell doesn't mind overlapping geometry. I don't know if using 2 planes will give you desireable results, best way to tell as Maxer stated above is to just try it. Render one image with the glass as 2 planes and then another with glass as one plane with thickness... compare which one looks better as well as how long they each took. As for a glass material the built in mxm wizard can create glass and/or AGS. If you have a specific problem with the glass mat let me know. Link to comment Share on other sites More sharing options...
