Ruben Drakkar Posted December 11, 2007 Share Posted December 11, 2007 I am rendering a scene of 800 k polys with 2048 jpg image texture files. I have also 2 computers dual core of 3.00 ghz and 3 gb of ram and this is the error that is coming up when I am trying to render one image with both computers. See the Images: this is what is happining to my render it get frozen This are the errors look the red dots Please I need some help with this. PM me or send something on this thread Best Regards Rubens Link to comment Share on other sites More sharing options...
WAcky Posted December 11, 2007 Share Posted December 11, 2007 im pretty sure the ones you've marked arent errors. I believe this is just mental ray cleaning out your memory so it can start processing more objects. Have you turned on all the memory saving functions as well as set a limit that a little bit under the amount of memory you're running in your stations? Also, dont render out such a big FG map. Try rendering out an FG map at half your render size. Turn off displacement when creating your FG map, save it, freeze it, crank the rest of your setting and go for it. One of these things should help you get there. Link to comment Share on other sites More sharing options...
omid_221 Posted January 10, 2008 Share Posted January 10, 2008 hi i dint know what is your problem but can u tell me how can i setup a scene for render on 2 pc's? Link to comment Share on other sites More sharing options...
