Automated Reduced Colorbleeding
nisus
Hi all,
Does anyone knows a short way of reducing the overall colorbleeding in a scene? I have to radiosity override over 100 materials and I don't want to do it by hand...
rgds
nisus
ps: I rtfm-ed but didn't find a clue on it (héhé)
ok, use this. adds/subtracts a value to every colorbleed parameter in the scene radiosity override materials.
paste & execute it into the 'new script' window.
---SCRIPT START
new_value=-0.1
--change new_value, negative values allowed.
--will be added to the existing value.
for i in SceneMaterials do
try i.colorbleed+=new_value
catch ()
---SCRIPT END
if the new colorbleed value would be higher than 1 or smaller than 0 (not possible), nothing is changed with that material.
better would be a little clamp routine, for too high values, and some input UI, but i'm too lazy right now ;)
Nisus,
Under Customize\Preferences\Gamma check if you have Enable Gamma Correction turned on. You can turn it on and control "Reflectance" as viewed on the Material Editor for all your bitmaps by changing the Input Gamma level. Perhaps you won't need to Radiosity Override but the solid colors. It is like teaching VIZ how to see (....). Of course, the brightness of output images is controlled by the Output Gamma value.
Ismael Orozco (Chico)
