PGD Posted December 18, 2007 Share Posted December 18, 2007 I'm rendering with vray so put the thread in here In short I have an animation rendering through backburner and two render nodes. I have calculated the light and irr maps which are stored on our server. Problem is while both machines will render seperate jobs without a problem, once a machine is free it wont help the other machine out. So a machine is sat idle while the other churns away at hundreds more frames Why are they not sharing? Use all servers was checked Link to comment Share on other sites More sharing options...
JamesTaylor Posted December 18, 2007 Share Posted December 18, 2007 sometimes backburner can allocate large sections of a job as 1 block, it could be the case that this is happening in your case. Its easy to find out tho, simply look at the task summary tab of backburner to see if all frames have been assigned to one node. have to say tho that i've only ever encountered this when using vray, precalced maps and split render mode. Link to comment Share on other sites More sharing options...
PGD Posted December 18, 2007 Author Share Posted December 18, 2007 One frame at a time is being allocated If a try batch rendering it'll swap nodes, not get them both on the one job Its like the pre calc files cant be shared by two machines. Render farms must get round this very easy... Any ideas anyone?? Link to comment Share on other sites More sharing options...
Nic H Posted December 18, 2007 Share Posted December 18, 2007 update your bb on the manager comp to the latest from autodesk site will solve problem! Link to comment Share on other sites More sharing options...
PGD Posted December 18, 2007 Author Share Posted December 18, 2007 I updated to Max 2008 recently and hoped that would have installed the newer bb with it Will give it a go. And it works! 2008 was only installed recently so wasnt expecting newer versions already. Sorted now though, thanks to those who replied Link to comment Share on other sites More sharing options...
Tim Fairbanks Posted December 18, 2007 Share Posted December 18, 2007 Also, if the 3dsmax 2008 installer detects previous Backburner installations it will not automatically upgrade to the latest version included on the installation DVD (ver. 2007.1.1). Previous Backburner installs must be removed before upgrading to the latest version. TimF Link to comment Share on other sites More sharing options...
