How do you clear it out?
Devin Johnston
I've created some models using Maxwell and I've needed to use them in Vray so I've merged them into my scene and replaced all of the materials. However now when I try and render the scene with a computer that doesn’t have Maxwell installed on it I get a missing .dll error and the machine won't render. As far as I can tell the scene has no Maxwell materials in it so I don't know why it's saying it needs Maxwell installed in order to render a Vray scene. Any ideas how I can fix this?
Well I've looked and I know which objects are causing the problems but there is nothing attached to or applied to them that have anything to do with Maxwell other than they originally came from a Maxwell scene. My work around is to install the .dll onto all of my machines, that works but it's still bothering me.
Not sure if that missing dll issue is quite related, but I've had good success with using the "KillMissingModifiers" script in the BSpack when I get missing modifiers in a scene. Not sure if materials quite fall into that category, but it's worth a try. That BlurScriptPack is here:
http://www.neilblevins.com/blurscripts/blurscripts.htm
Certainly sounds like an annoying problem. Good luck with it.
